My fuel system woes continued today. The new fuel pump arrived - that bolted on easy enough - and I used yellow teflon tape on all pipe threads (i.e., not flare fittings), on the pump and on the glass bowl filter. I put the new fitting on the output side of the filter, snugged down the fuel line, and gave it a crank. Doncha know Faulkner fired right up! And gasoline was everywhere…
I wiped everything down, and removed the steel line between the filter and the carb. You know, those steel flares look clean as a whistle, I don’t get it. So I backed out the brass fitting I just bought at NAPA, and gave it a closer inspection…
Damn! It’s for an SAE 45 fitting, there’s no seat for the flare!
I’m hoping it’s just this fitting that’s giving me grief now. I want to keep the glass bowl filter, but I don’t know if that rubber grommet is still good and contributing to the leak. (Hard to tell with gas spraying everywhere.) I got new parts for it 14 years ago, from Claude at Fuel Pumps A2Z. They used to have a website back then, but it’s now defunct. There’s this Facebook page with a phone number, maybe I’ll call them tomorrow and see if they’re still in business. I can make out the P/N for the Carter filter - 2146397 - and there are plenty of used ones on eBay, I would just like to buy new parts for it.
So, I’m on the hunt for the right fitting. The flared tubing is 5/16" OD, the fitting for the flare is 1/2", and the NPT to the filter is 1/4". I doubt Lowes has it, but I’ll check in the morning.
In other news, I slapped the brakes back together on the passenger rear (where I had replaced the seals), I used a little emory cloth to break the glaze on the old shoes like my old man showed me. They just have to work well enough to get to the shop, where all new parts will be installed. I didn’t bleed the cylinder yet, I just didn’t have the heart to take that on at the end of the day.
Family is coming this weekend! It remains to be seen, if I get the U-joint in the driveshaft and put that back in with whatever time is left. And the days are growing short…
