Lucky man Dan, those floors really look good. Ospho, encapsulator, sound and heat barrier and you are good to go. The gas pedal has a rubber boot (Gary Goers) that hangs under the floor. Take the pedal off and you will see a plate with 3 machine bolts, soak good with penetrant then remove, the boot mounts under the plate. Dan l recommend you get a tub of white grease and with a light of some kind smear the grease on the window operating mechanisms moving points, sliders, rollers, exposed gears etc. It’s a messy job but well worth it. It’s easier with your fingers than a brush.
