Converting the Forum to a Gallery Style
I know, I know - I keep talking about it. But now I’m actually ready.
I want to convert the Forum to a gallery style with these features I’ve mentioned before:
Producing a thumbnail for a pdf file was not an easy trick - but I managed to hack it. And then - because some folks like to post images on the forum that are stored outside the forum - I realized that I had to deal with that, because it spoils the gallery layout. And now I’ve got a fix for that as well!
So, I am ready to take the plunge. It will be disruptive for a while. Thumbnails will appear with an inconsistent size; links to external images need to be modified; pdfs need to be re-uploaded to generate an icon; certain movie types need to be converted to mp4 (mov’s will play with the embedded player now, finally). I’ve identified all the posts that will need fixups, and will start working my way through them as I watch NetFlix :unamused:
After that, I’ll start moving content into the Forum. I’m not T.W. SWM for nothing (The World’s Slowest Webmaster)! Bear with me, I hope you like the end result.
Well, I took the plunge and converted. Can’t go back now :astonished:
And it seems, for the most part, to have worked. Check out the gallery style in this post. What do you think?
Still, not all the thumbnails got converted - and some images have an orientation problem. I have to look at that. And then, because images “wrap” on a line now, so does the text that follows an image! That makes for an odd effect, I have to correct that.
All told, not too bad an upgrade. I’ll work on getting those things fixed, while I now start converting movies.
Ooh! Here’s an even better example - Dick’s “How To” on the 318 oil pump…
