361 - Project
  • more pictures
Some pictures – before and after
  • Looking back gives me a chill
  • What a difference
  • the new, hardened valve seats are clearly visible here
  • exhaust valve before and
  • … after. The car won’t be a race car but a travelling car, therefore a friend dissuaded me to polish the ports.
Gentlemen,
  • may I present you the world’s probably youngest Mopar mechanic?
  • My son Francisco decided to help me with the 361. In fact he already shot a lot of pictures you have already seen before,
  • … but this time he is responsible for the proper fit of the head gaskets.
  • The heavy stuff is for daddy then.
  • “Fresh” overhauled cylinder head meets block
  • and Francisco closes the gab.
  • … some anti size for the new head bolt set
  • the little fellow does it all alone,
  • except the torque wrench of course.
(These pictures are not posed, I promise you)
Wow, Stefan, you sure are bringing Francisco up right! Soon we’ll have another mechanic prodigy on our site – another Matthew! :astonished:
Sure Dan, let’s hope so!
Here is something else I’d like to know:
Who is really watching this topic?
I know you are here Dan, and Ron and most likely Matthew, also Curt, Big M John, Tom and maybe Merle too….. who else?
Leave a note and let me know!
Stefan
Well, I know Ed Ober is, Stefan (hi, Ed! :stuck_out_tongue: ) – I spoke with him just the other night, and he’s been following closely.
I watch it, but I never get any pictures.
Hmmm… That’s odd, Dick. That’s typically what happens when you can’t log in – but, you can’t post if you can’t log in, either. Not sure what’s up with that.
BTW, Stefan, your post has been viewed 2996 times (as of this post) – I’d say you’re getting some heavy traffic…
Some thing very strange going on, now all the pictures are there ??? Stephan the oil pump on my 261 is leaking, where can I get a gasket kit for the oil pump only. Anybody.
I bought the O-rings in a local hardware store. And then I bought a leaf of gasket paper and cut the gasket where the pump is bolted to the housing – very simple!
Gee Dan, I forgot to mention Ed. Ed sorry about that!!! I knew you were locking but it passed my mind! And also Roger sent me a private mail… Great!!!
Well guys, let’s go on with the pictures:
Now is the time for all that little work to reassemble the block
  • a set of lifters – new of course
  • all together – well lubricated for breaking in
  • and a set of brand new push rods
  • I also use the cam shaft lube for the push rods
  • and valves – This should withstand the first minutes after the start up
  • an a new Double Roller Timing Chain – Thanks Merle for the advice!
  • Just for now I have to install the old rocker arms again. The new ones haven’t arrived yet. :frowning: Of course I’ll change it before firing up the first time.
  • In fact - nothing shows the progress better than these before …
  • … and after pictures. :smiley:
  • Rear main seal with – before
  • … and now with the new seals. These little edged side seals come from a later Pontiac model because the seals of the later BB won’t fit the early Blocks.
  • I really hope the seal holds. I hate it when oil drops out.
  • The new Valley Pan and the Timing Cover are held in place with only two bolts. The Oil Pump is already installed to stay.
  • Well, seems the block is finally ready to receive the new paint – Here the first color match - “Kawasaki Racing Green” Not original but extremely aggressive!
I have been too, excellent work!
Bob
