When I brought my car it came with a new windscreen and rubber. Went to install it today and found the new windscreen rubber is a two piece setup rather than the one piece one that came out (old one was completely stuffed so cant be reused) Has anyone done an install with these and if so where on the screen did you set up the joins? Side or bottom are the only option s.
