Transmission
Hi all
In search of a 1962 727 transmission
In my quest to rebuild my BB engine with a stroker kit it turns out that the 440 crank and my original converter / trans will not work
My research tells me that the 1962 727 has the shift cable and rear brake
With little modification I can make it work
If you have one you would be prepared to part with or know of where I can get one I would love the hear from you
Only catch is I may need some assistance in getting it to the shipping yard as it’s got to make its hall to Australia
Cheers
Vic
A special thanks goes out to John (Big M) as he has come thru again
Cheers John
You’re more than welcome, Vic.
I appreciate the business!
Did you install the '62 trans and did you use the '62 button mechanism with the '59 buttons?
Howdy
sorry for the delay
Believe it or not my trans is yet to arrive in Australia
I have had some significant delays with my transporter
I will keep you abreast of how it pans out
Cheers
Vic
