Just tried rock auto and all they have are gaskets no filters. What other sources should I try?
There is no replaceable filter in the torqueflit’s automatic tranny, it has a screen type filter that is washable, it uses no gaskets. You will need a pan gasket.
You can add an aftermarket inline filter on the existing cooling lines.
Thanks Dick
Thanks Ricky
