Time to get real
Oh, I should point out that both pairs of shocks they sold me are rear shocks… At least, I didn’t send these to Portugal :blush:
I’m really not anxious to put shocks in myself, and I’m not sure I want the muffler guy to modify them to fit either. Can anyone recommend a set of gas shocks that will just bolt in?
So far the parcel is still at the CO. Well, it seems you are talking serious. I already expected this as a revenge for something I recently wrote on the 59sportfury.net but until now nobody discovered it or thought it was worthy to mention.
I knew that the KG4507 need minor modifications therefore I suggested you to wait until I have my shocks here and installed. As far as I know you can choose between the original Oil-shocks and the KG4507 Gas-a-just shocks. To me the KG4507 appear to be the better choice. Regarding the minor modifications – that is nothing complicated with this. Any shop with a drill in a stand can grind the lower mount very precisely, just don’t do it yourself. If you don’t want to install them yourself then go to any tire shop. They do it all the time and you won’t squeeze your fingers.
Stefan
If you’re getting to that anytime soon, Stefan, perhaps you could take pix and tell me how much metal I’ll need to remove. That way, I can prepare the shocks ahead of time. I don’t want to take the chance that the machine shop will overheat the rubber grommets, as the Imperial site suggests…
Hi Dan,
A three-row radiator was standard for the V-8’s, I would think. To describe one, imagine 20 six-packs of beercans, arranged side by side.
The “core” is a series of flattened rectangular “tubes”, held in place by aluminum fins. The top and bottom tanks are soldered into these tubes.
The direction of flow is into the bottom tank and out the top tank. If your tanks are repairable, they will solder them on a new “core”. If your tanks are not repairable, you have to go looking for replacement tanks.
IF the KYB shock absorbers sound too complicated, check out Andy Bernbaum’s catalog. I do not know what brand he sells, but they are ready to bolt on. I have them on my car. (Note:.They were NOT the cause of the rear end sitting so high…I unbolted them and the car did NOT settle down, so I think that was due to someone modifying the leaf springs.)
Thanks for the clarification about the radiator, Roger – that helps.
I like the idea of going with front shocks from Bernbaum – that way I don’t have to fool with them. The KYB shocks for the rear (where I have the most problems) should fit fine. I think I’ll just take the credit for the front shocks from Summit, and order from Andy.
Sorry Dan, whatever you decide to do, but that doesn’t sound like a worthy argument to me. Why don’t you wait a couple of weeks? Soon when I get the KYB (the correct ones) I’ll start with them and find a solution, or not. Then you decide.
Besides the rear shocks from KYB won’t solve your problem. Your leaf springs are - just like mine - old and weak and therefore they are hanging down when Faulkner is loaded or has more than two passengers on board. The KYB will hold very little against this, will give more stability but won’t lift the tail or give you much more ground clearance. As Dick wrote a little up in this threat, you need air support.
Stefan
Well, they may be weak, but they’re not old – they’re from Espo Springs 'N Things, replaced about 4 years ago. I think my options were 4 and 5 leaf, and 4 were recommended for a 318. In hindsight, that seems like bad advice I got. I thought that perhaps I would get longer shackles to help with the height… Is that a bad idea?
Or, maybe I could borrow some height from Roger… :laughing:
Funny, Dan! I had lowering blocks installed this summer. Now she sits level.
You are too late, Roger’s car is perfect now :smiley: He had some lowering blocks installed and the height is good now. I have been talking to my friend Andre (59 Desoto) about installing these blocks in his car so he can get rid of the cement blocks he has in the trunk :laughing:
Hey Roger,
We posted at the same time, aren’t you supposed to be at work :sunglasses:
Ok, i missed that. Maybe we became simply too heavy? :confused:
Dan - As far as shocks go you ought to look at the shocks Kanter supplies, they have Gas-Charged, coil over booster and Pleasure ride shocks. If you don’t have a catalog go to www.kanter.com to take a look. You can call them for information at 800-526-1096. As for the rear springs adding an extra leaf in some cases raises the rear end 1 to 2 inches. I put new springs (4 leaf) in my red and white SF and then put 2" lowering blocks. It sits fine right now and the few times I had passengers in the back there was no problem with bottoming out.
Well, a couple of weeks back somebody bumped the Scion while Marie was waiting at a light. No apparent damage, and no injuries – but it obviously introduced an exhaust leak from the sound of it.
I took it to a local Midas shop, and started chatting it up with a guy there. It turns out he has several classic cars, and once owned a '61 Plymouth – he says he can tweak the KYB shocks per the recommendation on the Imperial site, no problema (and put in a new exhaust system too, of course).
He called me to say he put a little heat to the Scion exhaust pipe to straighten it, and tightened a clamp – it’s fixed, no charge. I like that!
…so, vacillating back and forth as I am, I think I’m gonna order the shocks Stefan ordered, and beat him to the punch. (Howzat for a dare, Stefan?)
Meanwhile, what do folks think about the shackle idea – is that worth trying?
P.S. Ron, in Philly, we don’t use cinder blocks – we throw bodies in the trunk. Have to change them routinely, of course…
That wouldn’t work in the Netherlands, with our climate you would have to change them at least every year :laughing: But I have seen pictures of Roger’s car after it was lowered and it looks great! Maybe Roger should post some new pictures with the improved look of his car.
And then there is the Dutch guy who disposes bodies in the ocean :imp: Last night people tried to lynch him and almost got somebody else, I hope they find him soon and before the police does. Sorry for this not car related piece of text :frowning:
Well Dan,
it sounds good to me! Next October you can compare it!
Stefan
Well Dan,
I might be wrong, but I don’t think so. I believe that this will be the best solution for you! Mostly next October you can compare it!
Stefan
Be careful with the shackles, Dan. I put longer spring shackles on my '67 Mustang fastback (back in the day) and was pulled over by Wis State Trooper for altering my suspension. No fine, but he gave me a few days to remove them. By the way the trooper was Myron Krieg, father of former Seattle Seahawks QB Dave Krieg (Roger must remember him). Stefan mentioned Gabriels - my Gabriel shocks work fine on my car and I’ve had them on probably for about 5 years now. I replaced my 4 leaf rear springs with 5 leaf. I think wagons came standard with 5 leaf. My $200 parts car happened to have a set of very good 5 leaf on it (along with a good radiator, transmission,glove box liner, etc) On my orig SF back in '60’s I think I broke rear springs at least 3 times. Right now my 4-dr Fury has a broken leaf spring. So 5 is the way to go. What about rearching and adding an extra leaf or dust off the piggy bank and buy a new pair of 5 leaf.
Okay my turn to add my two cents - just catching up after 6 days away with the flu - very nasty this year.
I have to ask this question:
I had new 5-leaf springs installed at a local spring shop. The car sat high and could not be pushed down with all your weight. It rode like an empty dump truck bouncing all over the road in the rear. A well-known spring shop took the car in and de-arched the springs. The results were perfect. The car now sits perfect without shackles and without lowering blocks. I believe the cost was $109 total!!!
Am I the only one that has had this done?
So Dan - my suggestion is add another leaf at a reputable spring shop and have the shop adjust the arch at that time if necessary.
My experience with shackles was not great either. The springs will dearch themselves (especially near the shackle) and find their way back to the same ride height with no improvement for carrying additional weight. I do also agree that Kanter gas-adjust shocks with helper springs would be a great alternative or used in conjunction with the added leaf..
PS The first set of leaf springs from Andy Bermbaum were incorrect for the car and I had to eat the shipping back - they refused to pay even though it was their fault not mine!
Curt
Shocks with coil springs, 5 leaf springs, gas shocks, air ride, there are many possibilities to improve the ride. I just want to add that my leaf springs are also weak but I try to take advantage of this. At the moment I’m planning an air ride system for the rear axle. I’ve already tried this with a pair of air shocks from Gabriel and it works fine. The only problem was that I had to use one of these little noisy air compressors to raise the vehicle and then I had to open the valve in the trunk again to lower the rear end. An air tank and some hidden valves will allow me to control all this from inside. Pictures will follow of course.
