Source for Brake Shoes
Greetings, Gents. My '59 is out of hibernation and into my mechanic’s garage. We’re looking for a new source for brake shoes. Any suggestions? Thanks in advance for any leads. --Gary
Hi Gary; I got my front wheel cylinders over the counter at O Reilly’s auto parts but I don’t know about the shoes. I see on E-Bay Raybestos has them. Good Luck. Mark
Gary, are you a member of the Forward Look network?
There is a vendor by the name of Mobile Parts that has N.O.R.S brake linings that are the older asbestos type.
Why asbestos? it seems the semi-metallic Raybestos linings cause a harmonic squeal when applied, I’ve had this happen to two of my own cars, and just replaced a full set on a customer’s car for the same reason. Roughing up the drum surface and installing to softer linings solved the trouble in all cases.
Gary, I bought Faulkner’s brake shoes from this guy: Security Measure | eBay
I had to replace the rears because of the leak from my rear seal. I ordered 2.5" shoes by mistake, but he quickly remedied it with 2" (I think police cars had 2.5"). My brakes have always worked great, before and after this replacement! I don’t know why; I don’t plan on ever doing a disk brake conversion.
Hi, guys. Thanks for the great tips. I got a set of the old asbestos-type shoes from Craig Stanley at Mobile Parts on Long Island. They definitely do the trick, at least short term. For anyone in need of brake shoes for a '59, Craig can be reached at 516-485-1935.
