i need brake shoes and brake cylinders, for the front of my 59 fury, got and out lets?
not sure what that last part means, but for brakes u will have to take a drum off and see what size shoe and cylinder u have (as there r several sizes available). dont forget to also replace the hardware, it is cheap insurance, i, myself don’t care for the shoes coming apart inside the drum, especially on the front
. u should also take a micrometer and measure to make sure ur drums r still thick enough to machine. when u machine the drums, leave the drums on the hubs to get a true machining. any local parts store should be able to help u w/ all of this, but they will have to order from a warehouse, so it will take a few days. btw, replace ur inner seals and cotter pins as well. good luck --jeremy
I have had great luck with wheel cylinders from Andy Bernbaum wwwoldmoparts.com These are new and come with the rubber kits installed and ready to mount. I have sourced my shoes locally but Andy does show shoes in his online catalog.
Good luck
Tom Fox
