Well my car isn’t “perfect” it needs a few things and its not running the best, but I’ll get into that in a minute.
First the items:
I’d like to get my hands on the original air cleaner assembly for the car. It currently has a chrome aftermarket cleaner and it looks nice, but its not original and therefore it must leave. My father changed it for the aftermarket one sometime in the early to mid 80’s… then one day while cleaning out his garage in the early 90’s he thought he’d never need the “dumb thing” so he threw it away
Now we can’t find another one. -
A NOS or original replacement Carter carbuerator. Also is there a felt or fiberglass spacer that goes between the carb and the intake? I and my Father seem to recall there is suppose to be one, but I can’t find it in the garage, and I can’t find info on it on the web?? We have rebuilt the original carb twice and the car still dies when you try to accellerate hard from a standstill. The accelerator pump works, but the car still stalls. We installed an Edelbrock 600cfm (I worked at a parts store when I was in my teens and they had a bunch of them so they sold me one for $100) This carb works good, but seemed to run fat, so I consulted a local “Mopar guru” We’ve re-jetted the carb with 2 different setups and also changed the float level so there isn’t as much fuel in the bowl… It will hold the accelleration with the Edelbrock (no matter the config) but when you “get on it” the car just doesn’t roar to life… Its really slow compared to what I remember from several years ago. You really have to get on the gas to get up to speed. This isn’t the big issue though, I need to get the car running first, keep reading
The tube or hose that runs from the buttons to the transmission took a small rock one day some years back. Now there is a hole in it that I cannot seal. So when I fill the tranny with fluid, the next day there will be a puddle under the car, then I’ll add a quart then a puddle, you get the idea. I’ve never taken that assembly apart otherwise I could clamp another tube over it if I had to, but I’d like to replce it… is it hard and where can I get a new tube how do I take it apart…
Wellness:
The car really does run like crap.
Symptoms: From nearly the second you start the car there is
missfire, but it seems to run fairly well and is driveable, just not powerful, up to about 15-20 minutes when it gets all warmed up. Then you nearly have to run wide open to get moving and it really won’t run much faster than 60 mph, soon as you let off the gas and slow up a bit it really starts running bad, the miss is horrible then and it shakes the whole car even at speed. If you stop it immediately quits and is very hard to start.
Troubleshooting:
I’ve installed new points, condensor, plugs, wires, cap, rotor, tried both carbs, different timing, I’m right close to 12-13* now. Some years back the engine was rebuilt and heads were re-done with new valves and hardened seats so it doesn’t need leaded fuel. I’ve tried Chevron premium, with a fuel system additive, non-vented and vented fuel cap, an electric fuel pump, I’m back to the original pump. I’ve been thinking it was heat boiling the gas in the line before the carb. So I spaced the fuel lines away from the heads and anything hot. I’ve installed new fuel filters both clear inline and metal inline. Added a HD aux tranny cooler the Radiator was completely redone by a close friend of mine that is a radiator repair man, and we flow tested it at 32 gallons/min. Compression is right at 165psi on all 8, I’ve never had an engine that was exactly the same on all 8 before, but where they are all that high its not a burned valve… That is where I am at currently with testing… I have since done: Installed a 160* Therm. I’m trying to get more air through the radiator with a 6blade solid fan from an old Dodge with A/C. I also ordered a better set of plug wires and installed them. I will test these tomorrow if I get a chance, right after I take the pictures I promised.
I also would like to try a new carb, but I am skeptical if cooling is really the issue or not. Could the coil be the source, I havn’t tried a new one yet, but I’m sorta going all directions because my father thinks its the heat causing it to vapor lock, one shop thinks its the carb, another thinks its the ignition, and another thought it was not enough fuel, another guy thought it was too much fuel.
I just don’t really know what it is anymore and therefore I’m just confused and doing everything ![]()
Current thoughts: If the 160 therm and fan does not resolve the issue, (and I don’t think it will) then I was going to replace the coil try new points and condensor again, then I wanted to try to find that original carb spacer (if its suppose to have one) and a new carb. Also, exactly what plugs should I install. I have AC Delco’s in there now, but I don’t exactly remember the number… what are the recommendations?
A thought came to my father, that I have personally never seen, is it possible the timing chain skipped one or two teeth? I highly doubt that could be it, but it does have a small miss that gets worse so I don’t know. Oh I had most of the exhaust system replaced, new mufflers and tail pipes, it sounds good, better than it runs though ![]()
I think the next thing I’m going to do is rip out the 318 and install the warmed up 383B that I have sitting in the garage…
I know it runs awsome. ![]()
So what do you think? Any and all info would be appreciated… I know its a lot of stuff but help in any area of it would be appreciated the car is not going to any more shows until its running, its too embarrassing pulling in the show with a car that runs like a 20 yr old clapped out clunker!
(but this one doesn’t smoke) ![]()
