Front Bench Seat tracks
I hope I am calling these things the correct name. The adjustable track that moves your seat forward or back that bolts to the floor. The part that bolts to the floor is nearly gone on both of mine because the floorboard is rusted out in those areas. Any decent used ones out there?
John Fowlie on the Forum can fix you up on these tracks, He has a salvage yard in Nor Cal that deals with our cars and has several 59" in stock there he parts out.
Hi Forum Handle is “Big M” Here is his web site for you to contact.
http://www.bigmauto.com/
Thank you for that information.
Dreamer - I take it your seat tracks are OK but you need the Seat Floor Pan they attach to. There is a set of those floor pans on ebay right now. The seller is classicparts4u. To to ebay motors search “Plymouth 1959 Seat Floor Pan”. I’ve done two rebuilds using thier pans.
My floor pans are gone in those areas but the seat tracks are also damaged. The part of the track that fastens to the floor pan is also rusted and partially gone. There was some bad rust going on in those areas.
Your best bet for the seat tracks as John Quinn said, Big M. John Fowlie in California.
