CLIPS
Where can i get clips for lower stainless back glass moulding,for 4 door Savoy? THINK IT TAKES 10.
Leonard; Post A picture of the clip if you can, Mark
they are all missing.
Leonard,
Dick posted here, where you can get them: Faulkner gets a redo - #2 by Dick_Koch
I’m poking around on his resto posts, to see if I can find a pic. Failing that, I’ll take a picture of mine, recently removed.
Dan, Leonard - The clips can also be found in Gary Goers Catalog #10, page 40.
www.garygoers.com
Thanks Dick! Leonard, here’s the direct link to that part of the catalog - go to page 40, and Dick notes:
http://www.garygoers.com/cat10B.pdf
Here’s a snippet from page 40:
It’s “C” that you want. You’ll find an order sheet at the back of the catalog. Here’s a couple pix of mine (yes, Dick, I know that I have to clean them up, osphol them, and use sealant when I reinstall. I’m learning from the master!):
Note that Gary says you need 7, which is correct for the long piece of trim. However, there is an additional clip needed at each end for the end trim pieces, each of which is held in place at the other end with a stainless screw. So, a total of 9 is needed.
Thanks Dan that helps alot,the 59 forum is really good I thank everyone who has helped. Getting the Savoy ready for the meet in Kerville Texas hope to see you’all there.
Another shot,looks like A sealed pal nut as well.you can contact Jeff at restoration specialties if you need another source good luck. Mark
found a source for clip’s and other things. RJ&L FASTNERS IN NEW YORK,THEY HAVE A WEBSITE.
Leonard; That is where I have been getting my “universal t’s” and pal nuts at. He is cheaper than the one in Windber Pa. his shop is near Rochester N.Y. He was at the spring swap meet in Carlisle Pa. last week and I had to wait for him to get back. Fast ship for me anyway,(about 2 days) to Erie Pa. Good guy I have talked to him on the phone. Good luck Mark
