Update. Removed cable at tranny end. Rooster comb mives freely through all gears.
Grabbed cable with vise grips. Cable will not slide in sheath. It; s disconnected from shift mechanism.
Next I will pull cable out and examine for kink or pinch. It is hard to see much of it. I can tell you in trying to look at it I learned it was hard pinched between the steering gear and something solid. More to come when I get the cable out.
Thanks for the help.
I’ll post a pic of the clip that holds it at the tranny end. It’s hard to describe. It’s in a spot thati might not photograph though. A pic of it would help anybody struggling with getting the cable out.
Update:
The problem was a pinched cable. She’s back on the road tonight! Your help was key. Thank you for the pictures and explanations.
The debris pic was intended to show that the fluid was bright red save for the tiny bit of material on the bottom of the pan. I did not intend to post. I’d taken precautions to prevent that mess but they fell short. Pitiful…
The pics of the shifter and relative cable position were very useful as was the explanation re adjustment. Likewise cable removal from tranny. My tranny is a '60 and the 57 manual with 59 supplements I have are not very helpful. If I can figure out how to post the pics I got in private emails I will. Very handy.
O’Reilly’s had a multipack of various sized cotter and R clips in their help section. Some in the blister pack were small enough to work at the shifter There were several, which was good because I lost many.
By the way, the cable relaxed enough laying overnight on the garage floor to be moved in the sheath. No way I would risk putting it back on the car. The new one went on. My brother-in-law wants me to do a postmortem on it to figure out what caused the bind. It was jammed something fierce. Odd.
Good Job! The 59 A 466 transmissions have two different valve bodys, the better is the one like the 60 or one piece, like you have. I personally would not have had any problem reusing the shift cable again. That being a’ Known good part’ is definitely a better choice. Good luck in the future, be sure to thank Dan for having me respond to your post.
