brake, parking and turn signal lights
Here’s an interesting conversation between Art Schlachter and Dick about lighting - has lots of useful information.
Art, if you need any help with your account - password reset, etc. - let me know and I’ll fix you right up.
Hmmm… Perhaps we should give Dick his own column. “Ask Dr. FiftyNine” :laughing:
Dan; I had A problem in the past, my brake lights would work some times, some times not. It was caused by A sloppy right turn signal switch contact. I had replaced the brake light pressure switch, checked all grounds/bulbs etc.etc. The brake lights would work, then when I made A right turn while driving out and about and I returned back home they would be out. very frustrating. I discovered it in the garage while wiggling the turn lever. picked up A n.o.s. switch and has been all is well ever since. Just thought I would share this as well. Mark
Thanks Mark! A quirky thing. I noticed yesterday as I was fishing for my fender skirts ( :open_mouth: ), I have a turn signal repair kit in my stash. Picked it up somewhere along the line, just in case. Often I have to return the lever to the off position after a turn, but the lights otherwise seem unaffected. I’ll live with it… For now.
Yep, really weird but the brake light wires run through the steering column to the turn signal switch.
Dick and I found out when we were working on his red 59.
Still need to fix this issue on my dads car
Matthew, if I’m not mistaken - this is because the outer lens bulb indicates 1) the parking lights are on, 2) the driver intends to turn, and 3) the brakes have been applied. The parking filament is separate from the filament used to signal braking and turning, both in the same bulb.
If the driver applies the brakes at the same time he turns - and, if you didn’t interrupt the brake wire (by running it to the turn signal switch) - you would not get an indication that a turn is intended, because they light the same filament. You do get an indication that the driver is braking, because of the steady light from the opposite side.
Have I stated that correctly, Dr. FiftyNine?
And here’s another question:
Why is it, that we park on driveways, and drive on parkways? I can’t figure that one out. :unamused:
DUUUH. Wa chu talkin bout.
Dr. Fifty Nine.
Why the wire from the brake pedal to the brake lights, goes through the turn signal switch…
I accept your explenation. In other words l have no idea.
I understand :mrgreen:
The turn signal and brake light wiring circuits were nearly the same on most domestic makes, '50’s through the late seventies.
I’m working on Martha’s wiring, and went looking for a good diagram for 6-wire turn signal switches that incorporate the brake light feature described in this thread - here’s a pretty good one that I found. You can see that when no turn is indicated and you step on the brake, both taillights light up. When you turn left, the left rear taillight is connected to the flasher, and the right rear taillight is connected to the brake switch and will light if you step on the brake. And, vice-versa.
