Bell Housing bolt patterns
Anyone know the answer to this question, put by Gary Pavlovich (of 318 performance fame)?
The bolt patterns are the same and if you have the 59 to 61 bellhousing you don’t use the plate.
Hmm… Gary begs to differ:
Sent: Saturday, March 21, 2009 12:18 AM
To: Morton, Dan
Subject: Re: Finally – an answer!
Dan,
Thank you for posting to the group. There is much mis-information but I thought it would be helpful to see what others had to say about the early and late Poly engines.
I have found that the bellhousing pattern is indeed different from the 56-58 engines and I suspect they are different all the way to 1961, prior to the aluminum case Torqueflite in 1962. The early 56-61Poly dowel pins and the two lower bolt holes are in a different location from the 1962-66 Poly 318 engines.
By the way, do any of your members have a 1959 Plymouth manual steering box for sale?
Thank you,
Gary
I have read the responses twice, and it looks like they say the same thing. other than the 59 to 60 bell housing do not use the plate, its inclusive. I will take pictures of one and post them.
Bell housing 1925826 also Dodge truck with A engine and Load Flite. Hollander number 408.
Thanks RickyMopar for pulling out the Hollander listing to show what interchanges with what.
I think you live close to me here in the Denver area… Are you the one with the 61 300G and other Mopars (Challenger, Hemi Super Stocker ETC.) I have been hearing about locally? We may have met at some point… I will send you a email to introduce myself. :slight_smile:
