Ride height
Ride height
Post by Matthew Keij »
Been checking out the ride height of the vert and the hardtop.
When we took pics a long time ago I noticed that the hardtop was a little bit lower.
Checking out the vert on the rear I noticed 1 side was lower. The difference between left and right is 3cm.
Is there a way to adjust this on the rear?
I found the bolt that adjust the torsion bars so the front is not a problem but I want to have the rear levelled correctly first
big m
Re: Ride height
Post by big m »
Hi Matthew,
There arer no afjustments to the rear ride height, I would check to see that your shackle bushibgs are all good, if so, then you probably have a leaf spring that has sagged slightly. This is common for the driver's side, as the weight of the driver over time can cause this.
It sounds like the difference is slight, and will not cause any issues, as re-arcing the springs can be costly.
---John
Re: Ride height
Thanks! I will check the shackles tonight.
Might swap out the springs if the shackles are ok?
Might not be a problem but I know there is a height difference of 1 inch between left and right.
Pretty sure it's going to make me crazy
Re: Ride height
Just a reminder from the prior owner, that after years of believing I had the correct leaf springs on the car, Tom Fox finally came to the conclusion that while the donor car sat at a "friend's" house, the "friend" removed the correct leaf springs and replaced them with incorrect ones. The replacement ones were too long, the shackles pivoted to the rear and the car's rear end stuck up in the air.
Just before I sold the car, I located some springs in a local salvage yard (from a '63 Fury HT) and put those on the convertible. Those springs must be, as John Fowlie says, sagging to one side after years of use.
I suspect you are going to have to save up and buy some correctly arced leaf springs.
Re: Ride height
Roger, I know :wink: I checked the topic of the leaf springs from that time.
I am putting the springs on from the Fury. If its too high again, i will swap them back.
Did the passenger side and it looks pretty good. A little bit too high but they mounted an non original spring on it so I will take that off.
The springs from the Fury are originals as the part number is still on there so we will see
Re: Ride height
By "Fury" I assume you mean the car you can only use for parts. That's a great idea.
Re: Ride height
Yes, that's the one!
I swapped out the drivers side this morning. Looks like the car is levelled perfect.
They one mounted a 6th spring onto the original 5. Not sure if I need to take that off
Re: Ride height
Matthew - One last resort. Switch the drivers side spring to the passenger side and the passenger side to the drivers side. Then when your abundant butt is driving the car will be level.
Always willing to help.
Re: Ride height
I never did determine how many leaves were on a factory original SF CVT.
I had a pair of shortie leaves (which would have made it 6 per side). Maybe I sent them along with the car.
Re: Ride height
Ok, here are some pics
Car as it is now, couldn't get a straight pic from behind
Side view as it sits now
The 1959 springs
6th non original spring. Should I remove it?
RICKYMOPAR
Re: Ride height
Post by RICKYMOPAR »
Matthew, What you have there in your photograph, is the good ol helper spring. I havent seen these for many years. They do work, in some cases they are just a crutch. You would jack up the rear of the car and bolt them on, thus adding to ride height and load capacity.
Re: Ride height
So, take them off?
Another pic of how the car stands now
Re: Ride height
Matthew - I would not take them off. I have helper springs on my Desoto and Green SF and even then sometimes when someone is in the back seat it will bottom out.
Denver 59 Fin Convert
Re: Ride height
Dick, when I rode in those two cars it did not bottom out right? So they must work! :oops:
Re: Ride height
John - As long as you stay in front!! Talk about abundant butts. Oh, I'm sorry, I didn't mean that, I forgot I stll may need some parts.
