En route to Carlise 2009, I sprayed those behind me with antifreeze leaking from my recently repaired intake manifold. I had it repaired, because it was leaking… (sigh) I’m resigned to the fact that sometimes, if you want something done right, you have to do it yourself. So after consulting with Ed Eckerson, I bought a set of NOS Offenhauser intake manifold gaskets from Gary Pavlovich:
Ed since learned that they are available new from Phethean Racing Products, P/N 5433 for $11.50:
http://www.offyparts.com/
[This link appears to now be busted; and a Google search does not yield a result… (sigh.) Best to check with Gary Pavlovich. -Dan]
These are “composite” gaskets, not metal (as are the FelPro kits available from NAPA) – and are more forgiving of minor fluctuations in the intake mating surface. The important difference, however, is that they must be retorqued – not only after installation, but after burn-in.
Here’s the 318 before I started:
Stripped of parts and manifold bolts, the manifold is ready to remove:
I work a thin-blade screwdriver through the sealer at the front end, and the manifold pops loose. Yow! That sucker is heavy! I end up lifting it off at an angle, and setting it on the floor. Then I peer at the block…
Oh no! There’s antifreeze sitting in pools, next to the lifters! How did this happen? I check the dipstick…
There’s no water in the oil. Whew! A quick phone call to Ed; this happened when I removed the intake manifold, likely from a pool of antifreeze within the manifold. Sure enough, where I set the manifold on the floor, there’s a little pool of antifreeze. I mop it all up, and per Ed’s advice, I “chase” it with oil poured liberally over the cam and ports; I’ll drain the pan and refill before I crank it up, and there should be no harm done.
Next, I clean the block and head surfaces, blocking all bolt holes and ports, scraping off all sealer and other deposits, and cleaning with alcohol…
The FelPro kit I had also bought – and ended up not using – has front and rear “spongy” gaskets, that dovetail into the left and right gaskets:
Ed has a great suggestion: Lock down the left/right gaskets to the head with short cap bolts, and glue down the spongy gaskets in position, knowing their exact placement with the left/right gaskets – let them set up, so that they don’t squiggle around when the manifold is reset:
Enough for tonight – tomorrow, I’ll reset the manifold, do the first round of torqueing, and let it sit again. Ed discovered that, within a couple hours, the bolt torque with the composite gaskets dropped – even without firing up! Whatever it takes, to get this finally right.
Here’s a pic of the intake manifold, all cleaned up:
To be continued…
