My sport fury does not have power brakes, though it may once have. I found 2 brake boosters and 2 reservoirs from old chryslers, and I suspect they will fit. What I am wondering is if this is a big job with regard to installing this upgrade? Are there any pointers, or things I need to know before I attempt this. Any help would be greatly appreciated.
Chad
both power brake units are from 59 imperials
thanks
Quickly checking Parts Books, I think you can use the Imperial parts. Yo uwill have to change out the pedal assembly (if it isn’t already PB), then install the vacuum tank and hoses, and of course the bellows..
