Lost spark and won't start now
Last Friday I didn’t have spark after rewiring my 59 Suburban. Hooked up a wire from the ballast resistor to the IGN side of the ignition switch and it started right up. Now, four days later, I have no spark again.
Anyone know what the problem is? I rechecked the connections and they’re all good. I have 12.5 volts at the coil and a new battery (it started on the old battery, but it was 6 yrs old so decided to replace it).
Any tips will be GREATLY appreciated as I’m supposed to drive it to the upholsterer for a headliner tomorrow morning. Ron
are you tapping in BEFORE or AFTER the ballast resistor? My first thought is the resistor quit. This has happened to me.
If so, bypass the resistor..( I think it is only there to keep the points from burning)
Thanks, Roger. I tried that but the actual problem was that I fried my Pertronix. I think it happened when I drug a wire across metal creating a spark. I understand that the Pertronix can be fried quite easily that way…and I did it. Put in a new Pertronix and the starter gave up. Put in a new starter and all is good now…well, except my baby has been overheating on freeway driving. Going to flush and backflush the radiator and put in a new thermostat. I think that will take care of the overheating…WHEW! Best to you, Ron
