Hello - I found a 59 Plymouth Fuel Sending Unit on Ebay. The link is attached. The last time I post someone said these were “suspect” at best. Does anyone have any experience or opinion about this unit and or compatibility and reliability? Thank you! John ![]()
John
I bought one of these from the same vendor. Basically it didn’t fit so I used bits off it to fix the old one. It wasn’t worth returning cos I’m in the UK. I did query with the vendor after I’d tried fitting the new unit but never got a reply.
Does this help? I suppose if postage is cheap enough to return then you may consider it worth a go.
Guy
Thank you for offering your experience Guy. I am still considering buying one though as there is nothing else out there I believe. Does anyone else have an opinion or experience? Thank you. John ![]()
Hi John - Check with Neil Freman at: www.fremanauto.com.
John - Scratch above. Make that: www.fremansauto.com
Hello John,
I know that this is an old e-mail of yours but I too am looking for a fuel sending unit. Where are they and how do I find one.
59 fury Johnnie J.
Search thru Vendors section on this List. Van’s Auto reportely is selling them.
Thanks, but on this list ?? were is this list ?? Johnnie
Over in the Vendors Forum, Johnnie – here’s a link. Don’t forget to click on the picture to render it full scale, if you have trouble making out the description or contact info:
