Will this fit my '59 4-door? My carpet is SHOT. It says 2 door, but… ?
Thanks in advance, all you forward-look brothers!
It should work fine for you. The only difference in the floors between a 2 and four door, is where the B-pillar is mounted on a four door car, and there is an extra brace beneathy the rear seat in a 2-door car. These items should not impede the use of the carpet you have found, although it may require trimming near the B-Pillars.
