# Camshaft
**URL:** <https://59plymouth.net/t/camshaft/612>\
**Category:** Tech Support\
**Created:** [October 5, 2005, 11:24am UTC](https://59plymouth.net/t/camshaft/612 "2005-10-05T11:24:35Z")\
**Posts on this page:** 1\
**Showing post:** 8
<div class="post-metadata">
**Author:** ![Faulkner](https://59plymouth.net/user_avatar/59plymouth.net/faulkner/32/21944_2.png) [@Faulkner](https://59plymouth.net/u/Faulkner)\
**Post date:** [October 6, 2005, 12:51pm UTC](https://59plymouth.net/t/camshaft/612/8 "2005-10-06T12:51:54Z")
</div>
> [@Gary Pavlovich](#):
> Stefan,
> The stock Fury grinds for 1957,58 were 256/.405 and 260/.405 respectively. Aftermarket grinds were approx. 240/.387 to 256/.400 or thereabouts.
> The cam you have pictured is not a Poly camshaft and will not work in your Poly engine.
> If you are in need of any Poly 318 information or New cams, New Poly finned aluminum valve covers, any Poly parts… let me know and I will send you information and pictures.
> Take care,
> Gary Pavlovich
> 402" Poly stroker motor
Thanks Gary – actually, I posted something about your cams on this site not too long ago:
> [@Poly Performance Cams from Gary P.](http://59plymouth.net/t/poly-performance-cams-from-gary-p/426/1):
> Just received this note from Gary: NEW Poly High Performance Cams 256/.435 (stock FP31 dual quad Fury grind) 210@.050 264/.450 or .480 Hot street grind 2000-6000rpm 224@.050 274/.480 2500-6500rpm 230@.050 284/.480 or .510 3000-7000rpm 240@.050 294/.495 or .525 3500-7500rpm 260@.050 $185 plus shpg. Or I can regrind your cam to high performance specs for $125 with your old cam as a core. Thank you, Gary Pavlovich [glpavlovich@cox.net](mailto:glpavlovich@cox.net) [fp-31\_grind.jpg]
_[View the full topic](https://59plymouth.net/t/camshaft/612)._
