Iam trying to figure out the data plates. I already got some help from Tom Fox as he cleared some things up.
I got 3 data plates here, 2 different types. There should be more different plates as Faulkner got a slightly different plate.
And Dick Koch got a complety different plate with more option codes on it.
I never seem a car from the Evansville plant that has a data plate.
LA plant used them as all the plates i have are from that plant. Think they changed the plate in the later build cars.
Plate 1 (early):
SG EW M1 M2 M3 M4 M5 M6 SEQ NO
I I I I I I I I
SO NO MODEL BT PT TR SP
IIII IIII MPII III II II
WCD LA
CHRYSLER CORPORATION
Plate 2 (late?)
SG EW M1 M2 M3 M4 M5 M6 M7 M8 M9
I I I I I I I I I I I
SCHED NO MODEL BT PT TR SP
IIII IIII IIII III II III
I noticed on Dan his data plate that he has AC stamped in it instead of SG and this is also build in LA. Has the second data plate.
Meanings:
SG = Solex Glass, 1 or 4 should be stamped under it if the car has Solex Glass
AC = Air Condition
EW = Electric Windows, a 4 should be stamped under it if the car has power windows
M1 = If there was is a 1 stamped under this the car is a 6 cilinder
M2 = If there was is a 1 stamped under this the car is a 8 cilinder
M3 = Unknown
M4 = Unknown
M5 = Unknown, seen this stamped at different cars with a 1
M6 = Unknown
SEQ NUMBER = Never seen this stamped
M7 = Unknown
M8 = Unknown
M9 = Unknown
SO or SCHED = Scheduled date, first 2 are the build month and last 2 are the day
NO = Unknown
MODEL = M, 1959 / P, Plymouth. After that is a 1 (6 cilinder) or 2 (8 cilinder)
Then there is another letter, L = Savoy, M = Belvedere, H = Fury, P = Sport Fury
BT = Body type, all the different body types, models and engines has different numbers. 292 means Fury, V8, Sport 2 door hardtop.
PT = Paint
TR = Trim, interior. This code tells you what colour the bolster and seat were in all cars.
SP = Unknown, probably means Special order
Anyone with a pic of a date plate, please post a pic so i can get more information!
I am happy to figure them out.
