Meet Valerie
Meet Valerie
I found my A Body wagon! '63, slant 6, pushbutton automatic. More to come.
Re: Meet Valerie
Looking good! 170 or 225 CID?
Re: Meet Valerie
It's a cast iron 225, Rick!
freeze plugs tell the tale - an iron block
Yes - the engine was rebuilt - two years ago. But alas, there's oil dripping from the torque converter housing!
I've other got a loose oil pan, or - as I suspect - a bad or improperly installed rear main seal. If push comes to shove and it needs to be replaced - can it be done on a lift without removing the engine? Or, transmission?
Re: Meet Valerie
Freeze plugs give that away, no freeze plugs aluminum block.
Re: Meet Valerie
I think both can be performed on the lift pan is easier when the trans is removed.
