LED'S in the dash.
Re: LED'S in the dash.
Vic - Are those strips available in colors and are they dimmable. The bulbs l used are dimmable. How are they connected electrically.
vic barone
Post by vic barone »
Howdy
It's just a typical electrical store called Jaycar
Runs a simple positive which I powered off if the light switch and then just earthed it to the housing
Cheers
Vic
My concertible has a 59 Desoto shifter that has its own bulb mounted to the front of the shifter to light up the plastic pushbuttons. I replaced the bulb with a green LED bulb and oh my gosh, take a look. Will try a strip on the heater buttons like Vic.
vic barone
Awesome
With the strip in place it will look even
Be sure to get one with a self adhesive backing
I then placed it in line with the plastic cutout
Bit of a tight fit getting in there
Cheers
Vic
vic barone
Me again
I assume you could get colored ones
In terms of dimming they work well when I turn the dimmer toggle
Yes, in fact I just ordered a green LED self adhesive strip that you can cut every 3 inches along with extra connectors just a few minutes ago. See www.superbrightleds.com.
