Power steering conversion kits for 1957, 1958, 1959, 1960, and 1961 Plymouth and Dodge
Posted: Sat Nov 02, 2019 1:39 am
by Fin-ish
I have a business (YouTurn Power Steering conversions) that builds and sells power steering kits for 1957 thru 1961 Plymouth and Dodge. We understand that trying to find an old replacement or N.O.S. gear or pump can be a daunting task and that is why we developed these kits. If you have a worn out system and are looking for a complete or partial replacement, we have you covered. 1957, 1958, 1959,1960, and 1961 Plymouth with the following engines; 277,301,318,350 C.I.D. and 1957,1958,1959,1960,1961 Dodge w/ 315,318,325,326, C.I.D. engines. This conversion kit includes a heavy duty power steering gear, Pittman arm (if needed), gear mounting adapter plate, power steering pump, pump bracket, pump pulley, pump cap, 2 groove water pump pulley (if needed), hoses and fittings set, universal joint, column extension adapter, column floor bracket and rubber boot, shaft extension (if needed), hardware and instructions.
Contact information:
Floyd Richard
YouTurn Power Steering Conversions LLC
Email - floydyouturn@hotmail.com
Ph. (409) 789-4064
