Trim needed
eroomas
Trim needed
Post by eroomas »
Hey Guys, I need a lower trim piece for the passenger side front door for a 4 door hardtop fury. I assume the hard top and sedan trim would be interchangeable. Thanks
Re: Trim needed
Matthew says they should be the same. Try Big M Automotive.
Re: Trim needed
Give me A day or two and I can see what I have. If I have A spare it most likely is dinged up bad. Can yours be buffed or beyond repair? I will check, in the mean time check with John. Mark
eroomas
Re: Trim needed
Post by eroomas »
Mark Merritt wrote: Sun Jul 14, 2019 5:27 pm Give me A day or two and I can see what I have. If I have A spare it most likely is dinged up bad. Can yours be buffed or beyond repair? I will check, in the mean time check with John. Mark
It's pretty bad, I'm afraid beyond repair unfortunately. Thanks so much for your help Mark
Re: Trim needed
I checked mine. I forgot how bad it was, plus the previous owner put A screw to hold it on instead of fix the clip. It is junk. I have seen them on ebay now and then. Len Dawson may have A new old stock, you need the part # to search his inventory. Google Len Dawson Mopar see what comes up. I am not good at posting links maybe Dan has heard of him. I will keep an eye out. Mark
Re: Trim needed
If you know the part number, you can search Len Dawson's inventory here...
Re: Trim needed
I'll check to see if I have one in good shape, and let you know.
Re: Trim needed
Looks like I have a good, presentable one available. There is one small door ding, but other than that, is nice.
eroomas
Re: Trim needed
Post by eroomas »
I'll take it, how much?
Re: Trim needed
How's $50 plus shipping?
You can call me at [530] 473-2225 to order by card, or use PayPal at bigmauto@colusanet.com I'll need your zip code to figure shipping.
I'm leaving for Colorado to pick up a couple cars on Sunday, so I'll be away a week.
eroomas
Re: Trim needed
Post by eroomas »
More than fair , ill giver you a call
